Bryan's 77 280z Auto Resto-Mod
Racerx3110
Post by Racerx3110 »
Pics will be added in the next few days.
A while back, as some are aware, Ashley really liked my Zcar and wished she had one. Easy solution I said, lets build you one!
First, what is the goal-what do you want your zcar to be?
Answer:
1) Must be an Automatic trans.
2) Must cruise freeway speeds with ease
3) Possibly fender flares of some type.
4) Must have some get-up-and-go.
5) Be able to be a daily driver to be able to drive it anytime.
6) Must have a/c.
7) Would like a Gate type shifter.
So these were my starting guide lines.
What's been done so far.
1) found a 1977 280z and we started out on this venture.
2) Dropped the 4sp manual, replaced it with a Jatco 4N71B automatic. This is a 3 speed auto with an Overdrive unit mounted between the trans and the bell housing and has a locking Torque converter.
3) Found a Mercedes gate-shift on Ebay and mounted it up.
4) Located an F54 engine with P90 head. engine was stripped of exhaust manifold, turbo, intake. I patiently waited for the turbo exhaust manifold to surface and finally found one at the right price. I had a spare intake with an aftermarket throttle body I had picked as someone's scrap sometime ago and I have a z31 turbo parts car so Turbo solved. Found the P90 was rotten through due to being run with only water and corrosion won. Replaced with an excellent condition P79 which has the same combustion chamber as the P90 but has shrouded exhaust ports.
5) Installed the "new' turbo engine and mated it to the auto trans
6) Installed an intercooler & piping
7) Installed 3" mandrel exhaust to ease breathing
8) Installed Poly bushings through out
9) Added power windows
10) Added power Mirrors
11) Added power door locks
12) Installed Overdrive (OD) lock-out switch.
13) Removed Clutch petal and installed an Auto brake pedal
14) Installed new cheap tires to allow car to be drivable until permanent tire size is determined
15) Installed Saden style a/c compressor & parallel flow condenser
16) removed and refurbished the interior a/c system including air vent tubing
17) Performed a Kia blower motor swap
18) Installed new door & hatch seals
19) Replace brakes all the way around
20) Media blasted and painted engine bay
21) Installed a 3rd brake light
22) Installed a forward facing camera to ease her parking and not bump the air dam
23) Installed a backup camera to assist her with backing up
24) Installed LED bulbs in tail and turn lights to ease electrical load
25) Installed a Walbro fuel pump and prefilter
26) removed old interior insulation and replace with Rattle Trap
27) Replaced all interior carpet
28) Replaced center console, mounted pwr window switches and OD switch.
29) Installed Radio and speaker box across that back of the car
30) Replaced headliner
31) Replace radiator
32) Rebuild door hinges
33) Replace door locks and rekeyed to match each other
34) Fogged interior to find/fix cabin leaks
35) Replaced horns
I'm sure there are things I've not listed
Interesting how long a list gets when you actually start writing it out..lol. We've all got our long lists :-)
Next up is;
Door shimming
Front daytime driving lights
Re: 77 280z Auto Resto-Mod
WOW you have been busy!!! Can't wait to see her car. Would be very interested to see some detail shots of your handiwork. Thanks for posting.
I don't know... I'm thinking that some pictures would really be needed here.... Who is going to believe a story of a build with an automatic without some pictures. :roll:
Racerx3110
I'll see if my resized pics will upload now :-)
The car is still in the Ugly stage as body/paint will be one of the last steps. Ashley is waiting to see the finished paint before deciding what she wants for the upholstery color/style. Pic loaded in reverse order ..lol
3rd brake light to help keep her safer
Ashley's Z -5752KB.jpg (67.16 KiB) Viewed 10164 times
Miata pwr mirror adapted
Ashley's Z -761KB.JPG (60.66 KiB) Viewed 10164 times
Z31 T3 turbo
Z31 T3 turbo
Ashley's Z -3466KB.jpg (52.49 KiB) Viewed 10164 times
Pulled interior and refurbished a/c and ran new harness  containing the new pwr options along with the oem
Ashley's Z -4356KB.jpg (65.8 KiB) Viewed 10164 times
engine out and media blasted for engine bay paint
Ashley's Z -6478KB.jpg (84.43 KiB) Viewed 10164 times
The wonderful interior, old and in need.
Ashley's Z -4404KB.jpg (60.56 KiB) Viewed 10164 times
How she looked the day she came home
Ashley's Z -4336KB.jpg (61.11 KiB) Viewed 10164 times
Racerx3110
Here are a few mores pics, I won't bombared with more for now :D
Just finished smoke testing for leaks. Found quite a number, some will be fixed now, others during the paint and body phase.
Ashley's Z -4315KB.jpg (49.69 KiB) Viewed 10159 times
3rd brake light in the dark. Gotta be safe :-)
Ashley's Z -4479KB.jpg (48.49 KiB) Viewed 10160 times
Ashley's Blue TURBO valve cover
Ashley's Z -6284KB.jpg (93.03 KiB) Viewed 10160 times
Camera monitor in the closed up position, tucks away nicely.
Ashley's Z -3182KB.jpg (46.59 KiB) Viewed 10160 times
Monitor flipped down showing Rear backup camera, doubles as a front facing camera in forward gears. You can see it was intended by the mfg to be dash and not roof mounted. It still works pretty well.
Ashley's Z -4280KB.jpg (63.7 KiB) Viewed 10160 times
New console with the Gate shifter for the auto trans, also visable is the OD button to go along with all new plush carpet through out.
Ashley's Z -5052KB.jpg (67.56 KiB) Viewed 10160 times
How long have you been working on that looks really good!!
Racerx3110
thank you, I can't wait to get to the body work so it will visually look like progress..lol! I actually started on it about 2 years ago, then progress stopped for about a year. Much of the work I did then. I have returned back to it now since the Corona.
I recently did the brake light, installed the console (bought about 2yrs ago), door hinges (still in progress as I will be doing the passenger side this weekend) and repaired my Low Fuel light function by replacing the Thermistor on the fuel sender.
I am about to fit a new air dam that was purchase a year ago and remained in the packaging till now. I just smoked the cabin for leaks, as well as, stopped some trans oil leaks. 240z bumpers will be mounted in the near future as well. Still a ton to do but at least there's progress :-)
Wow Bryan, you have accomplished a lot! Looking great. 8-)
Very impressive indeed. Has she moved under her own power yet? (the Z, not Ashley)
Racerx3110
Absolutely, been drivin it around for this last year here and there. I'm impressed it's getting 30+ mpg on the open road.
