Page 1 of 2
Need help
Posted: Mon Aug 12, 2019 9:24 am
by Ryanotown22
I need to get the wedge pin out of the striker arm it’s #2 underlined in red. There is no easy way to get in there to punch it out but maybe someone has better tools to accomplish this. This is on the 77-78 5speed tail housing. Willing to drive/pay for time whatever needed I just need that out so I can replace the o ring. It’s the same shape as the spindle pin lock
Re: Need help
Posted: Mon Aug 12, 2019 11:17 am
Can you get a C-clamp on it and slowly tighten it to push it out till it breaks loose? It may be too tight to do that. My other "go to" option for impossible problems is the Scottsdale Machine shop.
Re: Need help
Posted: Mon Aug 12, 2019 3:24 pm
by Ryanotown22
Yeah I tried c clamps and motorcycle chain breaker nothing fits in that small of an area.. I did try a crow bar but couldn’t get it out either. Do you have any contact for that shop?
Re: Need help
Posted: Mon Aug 12, 2019 6:30 pm
The owner's name is Bill. Phone number is 480-945-0934. They have solved some tough challenges for me in the past.
Re: Need help
Posted: Tue Aug 13, 2019 7:28 pm
by toylet
I have removed about 8 of them in my lifetime..let me know if you still need it out. There is a trick. I am in Mesa
Re: Need help
Posted: Tue Aug 13, 2019 8:22 pm
by Ryanotown22
Well I already started to drill it out now that I ordered a new pin.. but what is the trick?
Re: Need help
Posted: Wed Aug 14, 2019 9:45 pm
by toylet
I used a air hammer on the lever down towards the inside of the case with a nut on the wedge bolt and the thing pops right out
Re: Need help
Posted: Sat Aug 17, 2019 12:38 pm
by Ryanotown22
I drilled it out took me about 4-5 hours gradually stepping up bit sizes and hammering on the bolt.
This tool was the only thing that made it possible
Re: Need help
Posted: Tue Aug 20, 2019 6:13 am
by toylet
Hopefully you can find a new tapered bolt.. they might be no longer available.
Re: Need help
Posted: Tue Aug 20, 2019 7:28 am
by Ryanotown22
Yeah I found some on eBay before I drilled it. I already got it and put the new one in fits perfect. Now I am waiting on the o rings to arrive from courtesyparts
