280Z Service in the West Valley ?
gsitler
Post by gsitler »
Is there someone in the West Valley area that sevices 280Z's?
-Timing chain adjustments
-Tune up for lower Altitude (My Z is currently tuned for Colorado)
Re: 280Z Service in the West Valley ?
A couple of questions. When you say timing chain adjustments, what exactly do you mean? Do you suspect the chain has slop in it that needs to be taken up to set timing properly? If the answer is yes, you can do that with a little coaching from people on this site. With regard to compensating for altitude change, I'm assuming you still have the stock fuel injection system on your car, correct? If so, your ECU should be automatically making those adjustments, if it's still working. Others more acquainted with fuel injection may be able to suggest tweaks that may help run-ability at our local elevation.
gsitler
Post by gsitler »
Hi,
I'm looking for a Mechanic that works on 280z's.
Thanks,
Guy
