Machine Shop Recommendation?
Recomendations and referrals for automotive work
SCARZME
Post by SCARZME »
Looking for a local machine shop that can fabricate some aluminum spacers to go between rotors and hat to center rotors in calipers. I'm combining 280ZX struts and 300ZX hubs so I can upgrade 510 brakes and not have to buy new wheels/tires. Nothing complicated, just round disk with a center hole and 4 holes for mounting bolts.
Any suggestions?
Bob - Payson
72 240Z
74 260Z Turbo-Scarab
71 510 Wagon (project)
67 Roadster VG30 swap (sold)
Re: Machine Shop Recommendation?
How thick does it need to be?
When I did the Toyota brake upgrade those rotors needed spacers, which can be seen in this photo.
SCARZME
Post by SCARZME »
The spacers need to be 0.97" thick. Pretty close to the spacers John Williams made for my 240 to use the Toyota V6 4x4 calipers if I remember correctly.
Bob - Payson
72 240Z
SCARZME wrote: Tue Oct 05, 2021 11:52 am The spacers need to be 0.97" thick. Pretty close to the spacers John Williams made for my 240 to use the Toyota V6 4x4 calipers if I remember correctly.
OK, those from Silvermine were only 5mm thick.
Bob, do you just need to have some existing spacers cut down to the proper thickness? I had that done on my Roadster by Automotive Machine of Scottsdale. I guess that wouldn't truly be fabrication but modification. They can definitely do that. 480-945-0934.
