Ethanol fuel and limited-use Datsuns
Posted: Wed Sep 23, 2020 12:07 pm
Hi guys- this is a combo general and 240Z-specific post so apologies if it's in the wrong category. After I spent a few hours trying to get my 240Z started over the weekend, it reinforced how modern fuel and Datsuns/old cars that get limited use are a bad combination. And I need to drive my Datsuns more!
My electric fuel pump that was just a few years old was leaking, but I chalked that up to the cheapo Amazon pump I bought. After I replaced that electric pump with a new (different) cheapo one from Amazon, the rear SU was still not getting fuel. I then pulled the carbs off and both needle valves were pretty sticky with old fuel residue. The jet nozzles at the bottom, which should slide up and down when you pull the choke, were basically stuck shut too. I've ordered a carb rebuild kit and am now cleaning and rebuilding the carbs (Randy I have read about your float tool and would like to order one when available). I hadn't started the car in a little over a year and the fuel smelled a little varnish-y, so I drained the tank and put in fresh gas, along with some Stabil fuel stabilizer. By the way, I had the stock mechanical pump but it started leaking hence the switch to electric, wonder if modern gas eats the internals to those too?
I've read most modern pump gas has a blend of ethanol which is hard on cork and rubber, and to use non-ethanol fuel, but nothing seems to be local to the PHX area. There are also ethanol stabilizers (I ordered some of this stuff too which might help):
https://zcardepot.com/products/fuel-sto ... z-280z-510
And I've read of modern fuels sticking up valve guides- is there any treatment suggested for Datsuns that get limited use?
What do you guys do to keep your Datsuns running well (aside from drive them as often as possible!)?
thanks!
Austin
thanks!
Austin
