Engine rebuild part 2: Top end and final assembly
Posted: Wed Aug 18, 2021 1:51 am
Back on the engine rebuild i.e. Part 2.
I got the head on my bench, and after some amount of bleeding and colorful language removed the valves, valve springs, retainers. Marked items for refitting and to keep track of them. The valve stem retainers on this engine are tricky to get to, as there is quite a bit of structure surrounding and above the valves. The sharp machined surfaces are not friendly to your hands.
The valves on this engine were in good condition. There had been minimal carbon build up, and no sign of pitting or damage. I went ahead and cleaned them and lapped to the valve seats. Reassembly went smoothly.
I used a Tomei head gasket and ARP studs to attach the head to the engine. The torque when using the ARP studs is 90 foot pounds. I ended up using my old 1/2" drive "click" torque wrench for this as I just couldn't pull 90 on my 3/8" drive digital wrench. I suspect that a younger mechanic could have done 90 pounds easily, as the wrench is rated up to 200. Oh well.....
The bolts that attach the cam sprockets are torqued to 93 foot pounds. Didn't bother trying the digital wrench just grabbed the long handled 1/2" drive wrench. Happily, my timing marks were all in the correct position when done, so I installed the chain tensioner and finally the CAS. Will torque that bolt for the crank pulley after I have installed the flywheel.
Since I am running dual electric fans and upgraded lights, I went to a 90 amp alternator from a Nissan 240SX.
