Page 4 of 4
Re: James' 72 240z 2JZGTE build
Posted: Tue Sep 15, 2020 2:40 pm
by Racerx3110
Nice! Have fun with the autocross!
Posted: Tue Sep 15, 2020 5:01 pm
I see you had the same idea as Duffman and I, in terms of mounting your AEM gauge on the shroud, between the speedo and tach, where it can easily be seen.
Posted: Tue Sep 15, 2020 5:41 pm
by datsunfsu
Still hard to see when the turbo hit full boost though. I don’t have any data logging with the stock so I was going to video camera the wideband with the tach so I can tune some with the SAFC piggy back some.
I ordered a water/meth injection kit so I can crank the boost up some on our 91 octane max gas. Will need to tune some when that is installed
Posted: Fri Oct 16, 2020 10:17 am
by SCARZME
What meth injection kit did you go with? I'm using AlkyControl which has a progressive controller. Works well with great tech support.
Posted: Fri Oct 16, 2020 12:05 pm
by datsunfsu
AEM one. The new version has a built in check valve. I've only tested fitted everything to a switch that will engage my boost controller at higher PSI.
Posted: Fri Oct 16, 2020 12:06 pm
by Racerx3110
those look like nice units
