James' 72 240z 2JZGTE build
Racerx3110
Re: James' 72 240z 2JZGTE build
Post by Racerx3110 »
Nice! Have fun with the autocross!
I see you had the same idea as Duffman and I, in terms of mounting your AEM gauge on the shroud, between the speedo and tach, where it can easily be seen.
datsunfsu
Post by datsunfsu »
Still hard to see when the turbo hit full boost though. I don’t have any data logging with the stock so I was going to video camera the wideband with the tach so I can tune some with the SAFC piggy back some.
I ordered a water/meth injection kit so I can crank the boost up some on our 91 octane max gas. Will need to tune some when that is installed
James
72 240z, 2jzgte swap
SCARZME
Post by SCARZME »
What meth injection kit did you go with? I'm using AlkyControl which has a progressive controller. Works well with great tech support.
Bob - Payson
72 240Z
74 260Z Turbo-Scarab
71 510 Wagon (project)
67 Roadster VG30 swap (sold)
datsunfsu
Post by datsunfsu »
AEM one. The new version has a built in check valve. I've only tested fitted everything to a switch that will engage my boost controller at higher PSI.
James
Racerx3110
those look like nice units
