Speedo Driver
Re: Speedo Driver
Re: Speedo Driver
Thanks, Ryan, good to know. I guess you can swap out the 19 tooth pinion with the 20 tooth pinion in the gear housing?
Re: Speedo Driver
Yeah it’s just held in with a little roll pin easy to swap
Re: Speedo Driver
Just realize that being off 10% in MPH on my Z set up, I need to jump up 2 pinion levels (need to go from 19 to 21 teeth). I need to find a purple gear, which is like a unicorn, am afraid.
borini63
Re: Speedo Driver
Post by borini63 »
Hi Randy...do you still looking for a speedo Red Gear?
I have one if you want to pick it up.
Jamal
Re: Speedo Driver
Message sent
